Steering Center Reset
Posted: 18 Aug 2012, 02:56
by dan826
Will this unit recallibrate the steering center sensor?
Re: Steering Center Reset
Posted: 19 Aug 2012, 15:10
Not with the current software version. We are looking into implementing this function with the next software version as a few people asked for it.
Posted: 25 Aug 2012, 12:00
by dan826
That would be great. Dealer wants $110 to do this simple 5 minute procedure. I would definitely buy one of these if it supported the steering reset.
Posted: 07 Oct 2012, 16:21
by MrTorino351
hi,what does that actually do?
Posted: 08 Oct 2012, 11:56
by sonicii
This adjustment 'teaches' the VDC system what steering wheel position is 'straight'. The VDC system uses a steering wheel angle sensor, and needs to know what the 'straight' position is so it knows when you are actually trying to turn, and by how much.
Nissan recommend it is done after each wheel alignment.
Posted: 09 Jun 2014, 16:23
by socaldt
Hate to revive an old topic but has this been implemented? I am having the same issue and would like to debug the VDC using DataScan II.
Posted: 12 Jun 2014, 11:09
Yes. This function is now available under ABS -> Works Support
