Page 2 of 2
Re: Primera P12 ABS connection
Posted: 07 Jul 2015, 01:19
These diagrams are showing a k-line connection to the ABS ECU pin 11. NDSII should be able to connect to it if this is your ECU.
Posted: 26 Jul 2017, 06:10
by muhamad yunos haron
what is ecu id 72
Posted: 26 Jul 2017, 06:11
sorry what is ecu id 71
Posted: 27 Jul 2017, 22:10
Not sure what id 71 is. Did you get the ECU number for this id?
Did you try changing the "Ini Timer Offset"?
Posted: 01 Aug 2017, 02:44
my car is x trail t30 series 2 QR25DE
My ecu test got this result
ecu id 10 - active (ECM)
Ecu Id 22- active ( 4WD) - checked with other software ( car gauge pro android )
Ecu Id 28- active ( ABS)
Ecu Id 58- active (SRS)
ecu Id 71- active - ( change TCM ecu Id from 18 to 71 and got connected with the ecu part number 31036-EQ4A)
I'm using the unregistered version on NDS 2 and I cannot confirm if it is actually TCM ecu connected.
Can Tom or anybody confirm.
tq in advance
Posted: 01 Aug 2017, 11:09
Sorry got connected to TCM with ecu ID 71 result - ECU PART NUMBER : 31036-EQ40A, SOFTWARE VERSION: 0x803
Posted: 02 Aug 2017, 03:48
Does this means that Nissan Xtrail t30 qr25de series 2 is using k-line protocol for accessing the TCM ecu?
Anyone can help me confirm ti his before I purchase NDS 2.
