does anyone know if NDS2 software is compatible with Year 2005 Primera P12, 2.0 petrol(QR20DE) abs unit?
I have tested the unregistered version of software but when I try to connect to the abs section, the program announce "no connection" and the buttons remains greyed also there is ECU PART NUMBER XXXXX-XXXXX?
I can only connect to OBD2-section and ECM-section.
PS.
Sorry for my poor english, I´m from Finland
-Veijjo
Primera P12 ABS connection
seb.racing
Re: Primera P12 ABS connection
BCM, TCM, SRS does it work?
no they doesn't work. Program says "not connected" to all of them, BCM,TCM,SRS,ABS,
Active ECU Test found 3 active ECU's( Id 10, Id 42, Id 71)
I changed Ecu Id's to those numbers which I got from Active Ecu test and I did get connected to BCM( ecu part number remains ##########, software version 0x710) , also I get connected to TCM (Ecu 31036-BA060, software 0x00) ,ABS connected (Ecu ########, software 0x710), SRS connected (Ecu ######, software 0x71), ECMD (ecu 23710-ba060, software 0x00)
seb.racing
hi
Unfortunately, I can not help you
send e-mail to Tom, he must know your problem
Do you have his email address? I can't send him PM.
Thanks,
-Veijjo-
Thanks,
-Veijjo-
seb.racing
The ABS ECU Id is 28. This ECU is not responding when you try to search for active ECUs. Only ECUs 10, 42 and 71 respond.
Your ABS could still be using the older Consult I connection (DDL1). This could be confirmed by checking the wiring diagram for ABS ECU. Would you have one available?
Hi Tom,
I have Electronic service manual but I'm not sure where in this manual I could find the wiring diagram for ABS ECU.
I found wiring diagram for ABS would it be helpful?
-Veijjo-
-Veijjo-
The ABS ECU wiring diagram should be in the BRC section.
Hi Tom,
I found these following pictures ( see the attachments) of ABS wiring in BRC section, are these any helpful?
Thanks,
-Veijjo-
Thanks,
-Veijjo-
- Abs Wiring 3.pdf
- (37.66 KiB) Downloaded 696 times
- Abs Wiring 2.pdf
- (43.1 KiB) Downloaded 662 times
- Abs Wiring.pdf
- (51.09 KiB) Downloaded 675 times
