hello i have replaced my bcm with a used one matching part numbers in my 2005 350z. when i connect to nds2 i can connect to the ecm and can read all ecus except the bcm when i do ecu search.
key pairing routine shows its reading key and finishes pairing but key is not being read by vehicle.
i know it is said nds2 cannot communicate with 2006 350z bcm due to different protocol. is this also the case with 2004.5 and 2005 350z?
does anyone know if a used bcm would beed to be paired/flashed to the vin of vehicle or the ecm it self via nissan since there is no option for this?
i tried connecting to my 2004.5 350z that doesnt have any issues, also cannot connect to bcm on bcm tab or read bcm ecu on ecu id search.
