ABS active tests greyed out
Posted: 11 Apr 2025, 05:06
by abosaad
Hello Tom
I have 2009 Nissan Altima, which uses Consult III for everything except ABS and SRS, for which it uses Consult II.
So, I bought NDS II just for that. See this post:
https://nisscan.com/phpBB3/viewtopic.php?t=913&sid=8712ef0c2926739a35db9d62e04106ae
Now, my problem is the active test options are all greyed out (except for the ABS motor). Please see the image:
https://i.imgur.com/RidMX8c.jpeg
Do you have any idea why? Any fix for this?
Thank you
Re: ABS active tests greyed out
Posted: 03 May 2025, 19:24
When the NDS II software connects to an ecu it checks which function the ecu supports. If the function is greyed out, it means it's not supported by the ecu. The ecu can disable a function due to some fault or the function is not supported by the ecu at all.
