First i would like to say that this is a very good software, thanks to the creator
Well, i have recently bought a Silvia S15 Spec R with a CARpc Infill G4 with NDS 1.52 installed. He's plugged to the ECU.
I have re-intalled windows XP and everything on it and i loose settings for NDS. I was using NDS 1.52 who works great.
Now i'm trying to install NDS 1.62 in trial mode just to see if this new version will work but i can't find the ECU in the communication setting.
I saw in windwosXP that the USB Serial port is located on PORT 17 (not COM1: GPS or Com2: ? i don't know what is for), so i've tried to set this port in the NDS, but it tell me that this is a invalid port !
I don't know in the setting also the adress read and ECU id and i f i have to check the box of 96 model Z32.
Please help me !
Thank you
