How do I set up my gauges?
Thanks in advance.
Beginner question : setting up parameters for dashboard.
No eye deer
Re: Beginner question : setting up parameters for dashboard.
1. Connect to the ecu you want to monitor. ECM for example.
2. Select ECM from the top menu then Data Display Settings.
3. Select the parameter you want to monitor for each gauge.
