Gadgets are not showing at "Data Display", but work at "Dashboard
nik300zx
Post by nik300zx »
Hi guys.
I'm using Nissan Data scan I version 1.63 installed at HP omen laptop with 64x windows 10 Pro and the connection is via 14Pin Diagnostic OBD adapter.
it started working only after I unclicked "auto" function and chose manualy to connect to COM5:
So, the connection is okay.
And here is the problem: "data Display" is not working.
But if I choose any gadget and put it on the dashbord then it works and shows the data realtime.
"Active test" is also not working :(
any suggestions?
Re: Gadgets are not showing at "Data Display", but work at "Dashboard
I think the issue is that you have RPM assigned to every gauge. Try other parameters as well and don't repeat them
