2012 Nissan Xterra & vag com kkl 409.1 ?
cocobug
Post by cocobug »
i cannot connect to ECM , connection is possible to BCM, ABS and SRS only
am i using the wrong cable ? do i need the vag can connector ?
Re: 2012 Nissan Xterra & vag com kkl 409.1 ?
Your ECM is probably using CAN bus for diagnostics. You would need the NDSIII software and the VAG K+CAN cable.
cocobug
Post by cocobug »
okay will try that, thanks a lot Tom
