Cannot connect Using vag kkk 409 (350z hr)
HOODEY
Post by HOODEY »
I am unable to connect to the ECU. Any ideas?
Device drivers shows correct port. Not using a the FTDI chipset.
Re: Cannot connect Using vag kkk 409 (350z hr)
The 350Z HR engine ECU uses CAN bus for diagnostics so you need to use a Vag K+CAN adaptor and NDSIII.
