Windows, drivers, Netframework
shotex69
Post by shotex69 »
Wanted to know if all windows versions are supported or not by Data scan 2, couldnt install software on windows 7.
On windows 10 installed it without problems, but Vag Com KKl usb cable driver had issue,finally seemed to be OK, when connected cable to diagnostic port,using free software(without activation) only ECU serial number appeared, so does it mean connection was successfull?
Re: Windows, drivers, Netframework
Yes, NDSII works on all Windows versions. The correct .NET Framework is required though.
If you are getting the ECU number that means you are connected.
