Compatibility Question?
keeway
Post by keeway »
I am interested in your NDS II product but will it be compatible with my 2001 Nissan Maxima GLE? Also if it is compatible and if the timing or idle is changed with your device will the settings be retained in the car’s computer even if the battery is disconnected?
James
nor_cal_spec-v
Re: Compatibility Question?
Post by nor_cal_spec-v »
> Thanks
> James
What engine do you have?
Here is a list of KNOWN supported vehicles... if your Maxima is compatible Yes it will retain idle and timing changes... This program is bad to the bone!!! :twisted:
Infinity FX35 (VQ35DE)
Nissan 350Z Z33 VQ35DE - ECM, BCM*, TCM, ABS, SRS
Nissan Almera Tino V10
Nissan Altima L31 (VQ35DE)
Nissan Frontier D40 (VQ40DE)
Nissan Maxima A33 (VQ30DE), A34 (VQ35DE), J31
Nissan Micra K11 (1999 or later)
Nissan Micra K12 - ECM, SRS
Nissan Murano Z50 (VQ35DE)
Nissan Note E11
Nissan Pathfinder R50 (VG33DE, VQ35DE)
Nissan Primera P12 (petrol)
Nissan Primera P11-144 (petrol)
Nissan Pulsar N16
Nissan Quest 2004+ (VQ35DE)
Nissan Sentra 2002 SE-R (QR25DE) - ECM
Nissan Skyline V35 350GT (VQ35DE)- ECM, BCM*, TCM, ABS, SRS
Nissan Skyline V35 (VQ25DD) - ECM, BCM*, ABS, SRS
Nissan Titan (VK56DE)
Nissan Xterra N50 (VQ40DE)
Nissan Xtrail T30 (QR20DE) - ECM, ABS
Nissan Sentra 1.8 (2001)
Nissan Patrol GUIII (TB48DE) - ECM, TCM
Infiniti M45 (Y34) (2003-2004) - ECM, TCM, SRS
keeway
Post by keeway »
> > Thanks
> > James
> Nissan Note E11
> Nissan Pulsar N16
I did see that list but i was seeing 2 different classifications of engines for my car, i have seen either VQ30DE or VQ30DE-K. i just want to make sure it will work before i order it...
thanks
James
sonicii
Post by sonicii »
the A33 maxima runs a VQ30DE-K engine. The -K (which is for Kaizen in japanese), has some improvements over the earlier VQ30DE in the A32, mainly intake manifold and plennum changes. it is still essentially a VQ30DE engine.
