Fuel Level Sensor 350Z
aZebest
Post by aZebest »
Hi Tom,
Can we check the fuel level sensor with NDSII on my 350Z ?
I would like to check the value of the variable resistance, because I have a difference on my fuel gauge.
Thanks in adavnce for you reply
Re: Fuel Level Sensor 350Z
The "Fuel Level Sensor" parameter should give you the fuel level sensor reading. It's supported by the NDSII software but it might not be supported by your ECM. Just connect to your car and see if it's one of the parameters that you can assign to a gauge.
aZebest
Post by aZebest »
OK I see, I will check on mt ECM and see if I can assign to a gauge
thanks Tom !
