ECM connection
gn22
ECM connection
Post by gn22 »
HI,ECM connection failed, but TCM, ABS, SRS, connection good any idea please thank you.
Re: ECM connection
What's the engine model you are trying to connect to?
gn22
Re: ECM connection
Post by gn22 »
VQ40DE ,2008 Nissan pathfinder petrol engine v6,thanks
Re: ECM connection
You should be able to connect to the ECM.
Try connecting from the OBDII tab to confirm there is no issue with comms to the ECM. If that works, try adjusting the Ini Timer Offset value under Settings->Communication.
gn22
Re: ECM connection
Post by gn22 »
Hi, I try that but does not work, adjusting the Ini from -5 to +5 nothing, thanks
