Nissan 350Z 2006 Phase II
aZebest
Post by aZebest »
Hello
I'm french, I have a Nissan 350Z 2006 convertible.
I bought software NSDII, installed , activated, and it works well with OBD cable VAG KKL 409.1 FTDI FT232 RL chip.
I printed out the User manual for a better understanding of the NSDII.
I have a question regarding the software in use with 350Z.
Firstly, I have done a scan of ECUs on my 350Z.
[attachment=0]ECU trouvés bis.JPG[/attachment]
The system does not show the ECU ID 18 normally for the TCM but it shows ECU 71, do you think I should replace 18 by 71 to get the right TCM ECU ?
Who does have a 350 Z to compare results in different ECU : ECM, TCM ABS SRS.... ?
Thanks & best regards
aZebest
ECU trouvés bis.JPG (56.78 KiB) Viewed 4699 times
aZebest
Re: Nissan 350Z 2006 Phase II
Post by aZebest »
Hi Tom,
What do you think about ECU ID 71 instead of 18 ?
Your TCM ID should be 18. Try adjusting the Ini Timer Offset rather than changing the ID. Try positive and negative values and try connecting every time you make a change.
You will only be able to connect to TCM if your car has an automatic transmission.
aZebest
Post by aZebest »
ok thanks Tom
I have a manual transmission.
