I have a 2007 350z HR and need to address the ECM.
I have installed NDS111 on two laptops Win 10 and Win 7.
Purchased from Aust. supplier, the recommended Commander VAG-K +CAN cable,( it only supports WIN 7); however Bitdefender found part of the software corrupted. Any attempt to connect NDS to the cable causes blue screen shut down. ( at this stage cable is not connected to the vehicle).
I have read one Skyline blogger who gave up after buying 3 useless cables; but he claimed success with a PP2145 Bluetooth interface bought from Jaycar.
Has anyone found this or another alternative that works. Also welcome comments on my blue screen crashes.
VAG-K + CAN fails. Is there a Bluetooth alternative?
Re: VAG-K + CAN fails. Is there a Bluetooth alternative?
Most of the Vag K+CAN adaptors use the FTDI USB chip. Have you tried an FTDI driver?
https://www.ftdichip.com/Drivers/VCP.htm
Im not aware of any Bluetooth Vag K+CAN adaptors. The Jaycar adaptor would probably be an ELM327 model which is not compatible with the NDSIII Windows PC software.
thanks for the reply. Im up and running with the android version. Cheers
