How to add custom logging parameters?
Gschrameyer
Post by Gschrameyer »
I found the config file but it doesn't have any instructions on how to add new logging parameters. Any ideas on how to add them in?
Re: How to add custom logging parameters?
When you start the logging function you get a list of available parameters. You just need to tick which parameter you want to log. There is no need to edit any config files.
The logging function is self explanatory and simple to use so you might be actually talking about something else.
Gschrameyer
I found out that the logging parameters are found automatically based off which CIDs are enabled and more logging parameters are made available if you enable them (Done by tuning.)
