Additional Work Functions
cs2000
Post by cs2000 »
Not sure if there's any way to do this, but thought id ask.
NDS II can already perform the "Idle Air Learning" function under ECM and Work Support, however theirs a few other useful functions that you can also perform using the "Pedal Dance" or key turning method, these are all shows on the Horsham Developments website.
https://h-dev.co.uk/350z-reset-proceedure-pedal-dance/
Is there any way NDS II or III could add these work functions in? Doing pedal dance/key turning techniques does work (just as it does with the idle air volume learn, but timing is a pain in the ass, its easier if you can click a button!
Whilst on the subject of idle air volume, these are certain conditions that need to be satisfied before the car will perform this relearn, they are:
Battery voltage: More than 12.9V (At idle)
Engine coolant temperature: 70 – 100°C (158 – 212°F)
Park/neutral position (PNP) switch: ON
Electric load switch: OFF (Air conditioner, headlamp, rear window defogger)
Steering wheel: Neutral (Straight-ahead position)
Vehicle speed: Stopped
Transmission: Warmed-up
Could the Work Support screen somehow accommodate these values and refuse to start the procedure of they are not met?
Re: Additional Work Functions
Thanks for the info and suggestions.
Unfortunately its not possible to initiate the Accelerator Pedal Released Position Learning or Throttle Valve Closed Position Learning functions through a diagnostic tool. Those functions are actually performed automatically by the ECU. The car just needs to be turned off and on a couple of times.
We have actually considered adding the conditions check for the IAVL function. There is a couple more parameters that the ECU looks at like Engine RPM, B/FUEL SCHDL and A/F ALPHA. If any of them are out of the "SPEC" value the procedure will fail. Unfortunately some of them differ between engine models and could create confusion for users.
Doing a simple check for the main ones is a good idea. We will look at adding it in the next update.
