NDS2 try before you buy, I'm trying
Tiny
Post by Tiny »
I'm struggling to set up NDS2 using Windows 10, a KKL OBD2 USB Interface Cable FTDI FT232RL Chip for 3rd Party Software & Apps, the correct drivers have been installed, com3 had been allocated, & saved
The car ECM is communicating with NDS somewhat, I'm getting closer.
Hoping for some input as to NDS's "Please test the unregistered version of the
software before purchasing.If you are able to connect to the specific
ECU (ECM, BCM, TCM, ABS, SRS, Diesel ECM) the other functions will work as well
if supported by the ECU.the other functions will work as well if supported by the ECU "
The only access I get is to the vehicle's ECU part number 23710-VG ,(build date 12-2000 Elgrand E50 3500 V6(VQ35), using a 16 pin plug)
Is this "normal" with the yet to be registered version of NDS2 ?
Input from Tom ? would be helpfull
Re: NDS2 try before you buy, I'm trying
On the E50 you should be able to connect to the ECM and SRS ecus. On the E51 we were able to test with ECM, SRS, ABS amd TCM. The registered version will not let you to connect to more ECUs then the unregistered version.
Tiny
Post by Tiny »
Thanks Tom ;)
