pda cable
hellraiser
pda cable
Post by hellraiser »
hi i have bought all of your cables over the years including the pda cable . my question is the ipaq pda when connected to a pc via active sync automatically turns the unit on,
with this in mind i have integrated the pda in a door card to de clutter the windowscreen. is there a way of adapting your cable to not only charge the unit which it does perfect but to also auto switch on when ignition is turned on? being an electronic novice i have looked through the schematic of the cables and pinouts on the datascan cable and the ipaq but its all above my understanding,
regards
gaz
Re: pda cable
I've checked with Jason from Blazt about it. Apparently it all depends on the capabilities of the PDA but he's could never do it.
