Need help guys... I just installed the Datascan software and it works great... but I need to know if something is not working right.
Can someone tell me the proper values for the following:
Air Flow
Air Flow Right Hand
O2 sensor
O2 sensor right hand
Throttle Position Sensor
Fuel temp
Intake Air Temp
EGT
Injector Time
Ignition Timing
AAC Valve
Air Fuel Base
Air Fuel Base Right Hand
Air Fuel Base Self Learn
Air Fuel Base Self Learn Right hand
Injector Time right time
O2 sensor B1
O2 sensor B2
WBO2
Thanks.
Nissan 300ZX TT 1993 proper values
onephatser
Re: Nissan 300ZX TT 1993 proper values
o2 sensor should oscillate very quickly between .1 and .9 volts. If they are slow to react or show different voltages than this, the sensor is bad.
