Nissan Patrol GRX, ZD30DDTI
eraser
Post by eraser »
Hello
I need a cabel for getting out technikal infos from my car.
I also want to see and clear errors.
Ma car: Nissan Patrol GRX, ZD30DDTI automatic, made in 05-2004
The car has a OPD-2 plug but I think its only a cosult 1 interface.
So I need a cable and the right Adaptor.
Do you know a combination wich will work and is also available.
Thank´s
Re: Nissan Patrol GRX, ZD30DDTI
You can use the NDSI Windows PC software and Android app.
You will need a Consult I adaptor with an OBDII plug. We recommend USB adaptors for the Windows PC software and Bluetooth adaptors for the Android app.
You can get the USB adaptor from www.ecutalk.com.au and the Bluetooth adaptor from https://www.obdinnovations.com/nissan-consult-bluetooth-14-pin-ddl-diagnostic-interface-v2-3
