ndsII CAN'T CONNECT.
Adam juroeng
Post by Adam juroeng »
I have a problem that I can't connect My software to reset My car. I am using KKL VAG.COM for 409.1
My car is nissan patrol tb48 year 2006.
Any one of you has same problem and solved.
Re: ndsII CAN'T CONNECT.
Try using the Find ECU function under Settings->Communication. See if you get any active ECU IDs. The engine ECU ID is 10.
You can also try adjusting the Ini Timer Offset value. Try positive and negative values. This may help with establishing connection.
