Tailgate in my Murano 2005 does not open.
I've checked all parts and cables and all seem fine till BCM module. This means whenever I supply ground to the switch cable on BCM end it triggers and opens the tailgate.
I got licence for NDS2 and it works perfectly with ECU, SRS OBD2 and other modules except for BCM.
Connection to BCM fails no matter which offset I use. I tried to scan ECU ids but software crashes when I try to connect to found IDs.Does anyone know the BCM id on Murano 2005 Australian models?
Also, to replace the BCM and test the tailgate, I got a second hand BCM with the same part number from a car wrecker but I cannot program immobiliser as I do not know the pin code. Can anyone help me with that?
Murano 2005 connection to BCM, Tailgate issue and BCM pin code
mkarbakhsh
