Ini File fails to upload
maxkarton
Post by maxkarton »
I am trying to get the Lite version of the software to connect to the ECU. I can connect to the Bluetooth adapter but not the ECU. It comes up with an "ini fail" error. I am using on one of the supported adapters from eBay. It is reporting via the software ELM v1.5. Any ideas?
maxkarton
Re: Ini File fails to upload
Post by maxkarton »
Couple of things I forgot to mention. I have a 2001 GU Patrol 4.8. And the PC version of the software works.
If the NDSII Windows PC software works, the NDSII app should work as well. Most probably it's an adapter issue.
Can you capture the debug log and send it to nissandatascan@yahoo.com.
maxkarton
Post by maxkarton »
HI Tom, I will send the log. I have tried another adapter and got the same issue. Cheers. Mark
