Cannot connect to TCM, 350Z
ninevoltz
Post by ninevoltz »
I have a 2003 USDM 350Z. I am using the blue USB cable I ordered from ConceptZ Performance that is supposed to be compatible with NDSII. I am able to connect to the ECU, the BCM, and ABS, but not the TCM. Any idea why that might be? I was able to program my new spare key into the BCM using the pin code generated by Nissan SuperCode. I had a hard time finding where to download SuperCode, would it be ok to upload it to this forum for other people to use?
Re: Cannot connect to TCM, 350Z
Is you car automatic or manual? It only works with automatic cars.
You can upload the SuperCode to one of the file sharing websites and post a link on this forum.
ninevoltz
Post by ninevoltz »
Yes, my car is an automatic.
As for SuperCode, I'll just share the link to where I found it.
https://www.4shared.com/rar/xAjK2QDDce/ ... Tools.html
Try the "Find ECU" function under Settings->Communication. See what ECU Ids you get.
If you are not getting ECU Id 18 try changing the "Ini Timer Offset" and scan again. Try positive and negative numbers.
