2006 Navara - ZD30
Flash!
2006 Navara - ZD30
Post by Flash! »
Hi.
I've tried Torque to connect to the Navara, and it fails - I'm told it should be consult II - its a zd30 3.0 diesel turbo, not common rail. It has an OBD2 plug.
When I try Datascan II, it connects to the elm 327 v1.5 (all good), goes through a variety of settings (as a little blue bar at the top fills) and gets to what I would say is 90% and then says 'ini failed'
NB Datascan II v1.5 lite.
suggestions?
Cheers
Greg
Re: 2006 Navara - ZD30
Your car still uses Consult I protocol for diagnostics. You need a Consult I adapter with an OBDII plug and the NDSI software.
