Hi, I have a paid version of NDSII, I have been having a problem with my 2005 2.2DCi Primera Estate where it shakes slightly at idle when cold, I have been advised by a member on NPOC forum to replace the Suction Control Valve on the fuel pump which i did and still the same shake there, I was thinking is it possible to hook it up to my laptop and use NDSII to watch all 4 cylinders when the engine is running and hopefully see one off a bit, I then have the injectors from my parts car to use if needed, I coud just swap all but i dont know the condition of parts ones and id rather find the defective one and swap it, Or maybe even test all 8 and pick the best 4.
Would this be possible or do i need to pay to have them tested properly?
