Cannot connect to R32 GTR ECU
Posted: 27 Mar 2017, 06:13
I recently bought a 14 pin consult plug from obdinnovations.com and downloaded the trial version of datascan 1.
I have tried this with both Windows 7 and 10. On both machines the software installs fine, the drivers provided by obd innovations also install fine and the plug seems to be functioning without error in either case. e.g. if I click "Connect" in the software I get 3 blinks on the middle green LED on the consult plug. Red led on plug is always on.
If I connect the plug to the car and attempt to connect to the ecu I simply get nothing. The green LED blinks as if it is trying to connect, but nothing returns from the ECU. No error messages, just simply nothing. Car ignition has been set to the ON position and also tried with the car running.
The ecu is the oem unit that originally came with the car. Car run's well.
Any ideas? I have tried reinstalling software, drivers, used various matching com ports but I can't get anywhere.
