Units of measurement in NDS2 - Patrol ECU and TCU
Mack85n
Post by Mack85n »
Where can I find what each output is in relation to for the given units.
Example : L/P solenoid ranges from 0 - 1. Is this in Duty cycle with (0% - 100%)
Also for ECU injectors is the units in pulse width.
Having 3.4 at idle on my TB48 would seem fairly close if it was injection duration.
Re: Units of measurement in NDS2 - Patrol ECU and TCU
The NDSII User Manual Rev 2 has most of the units for the ECM. You can download it from http://home.exetel.com.au/nds/NDSII/ind ... t=download
Injector Time is in Msec.
Most solenoids are in duty cycle 0%-100% or 0-1.
