NDSII Active ECU
JohnJ83
NDSII Active ECU
Post by JohnJ83 »
Evening All,
Apologies if this has already been answered in another topic
I'm new to the forum and NDSII and having some issues that I hope you may be able to help with.....
I have downloaded the unregistered version and connected via a 409.1
Settings>Comms>Find ECU is showing ECU Id58 Active, ECU Id FE Active.
From here I am a little stumped. When in the main panel view, ECU tab selected, I click on 'Connect' but constantly get 'Connection Failed'
Am I doing something wrong or missing something out??
I am trying to clear a fault code and get the truck out of Limp Home Mode
Thanks In Advance
John
JohnJ83
Re: NDSII Active ECU
Post by JohnJ83 »
Quick Update....
Purchased full version... Now able to access ECU 58 (SRS) but unable to access anything else??
Any help greatly appreciated
J
What car are you connecting to? If it's a diesel you need to be connecting from the ECMD tab.
Also try adjusting the "Ini Timer Offset" value under Settings->Communication.
