Hi
Does this support for Nissan Pathfinder 2003 SE Manual 4x4 in use in Middle East VQ35DE ENGINE. as attached image of ECU connects to before i bought BT Adapter ELM327 2.1 but does not give live data Or any PID, i can only clear fault codes , if connected by other expensive Device gives all codes etc. Kindly give solution.
BT ADAPTER-SOFTWARE FOR NISSAN PF 2003-MT
mustang4372
- 11.jpg (107.72 KiB) Viewed 4638 times
Re: BT ADAPTER-SOFTWARE FOR NISSAN PF 2003-MT
Our NDSII Andoid app and Windows PC software should work with your car.
See our website for more info.
Android app
http://home.exetel.com.au/nds/NDSIIA/index.php
Windows PC software
http://home.exetel.com.au/nds/NDSII/index.php
Android app
Windows PC software
mustang4372
Yes thanks it works as described.
Kindly describe as in NDSII v1.5 when i add items to Dash and rearrange them they look fine and usefull but when reopening other time the software all dash settings are gone and have to rearrange them again as they overlap each other on top left corner(Solved by unchecking allow edit).
