Teana J32 MR20DE 2011 ECU Connected
Chalermaon
Post by Chalermaon »
Hi!
May I have question?
1. I can connect ECM SRS and OBDII function but the rest are conn failed, I will can connect TCM and ABS after activate purchase? ( -5 - 5 try already)
2. In OBD II function, all monitor are not supported, this is normal for non activated version?
3. In OBD II function, retrieve error code is empty, this I wiil get error code after activate? (I have TCM error p1722 before with other scant tool)
I want to buy this product for trouble my TCM, please advice.
Thanks advance.
Re: Teana J32 MR20DE 2011 ECU Connected
To answer your questions:
1. I can connect ECM SRS and OBDII function but the rest are conn failed, I will can connect TCM and ABS after activate purchase? ( -5 - 5 try already) - No. If you can not connect with unregistered version you will not be able to connect after activating the software.
2. In OBD II function, all monitor are not supported, this is normal for non activated version? - No, it's not. It might be because your car doesn't fully support OBDII protocol.
3. In OBD II function, retrieve error code is empty, this I wiil get error code after activate? (I have TCM error p1722 before with other scant tool) - No, it will not. OBDII tab only supports engine ECU. You can not get TCM errors through that tab.
Chalermaon
Thank alot for your clear answer.
