Jaycar Scanner
Steve
Jaycar Scanner
Post by Steve »
Has anyone had any luck with the only hardware (i could find) that people in sydney can go out and buy when they need it (now)?
http://www.jaycar.com.au/obd-ii-engine- ... y/p/PP2145
And to the developers, Any thoughts on this one?
Thanks.
Steve
Re: Jaycar Scanner
Looks like the real deal. The Manual specifies "This product uses ELM-327 hardware" which would suggest they use genuine ELM chips. If this is really the case the NDSII and NDSIII apps should work just fine.
