Windows XP, KKL VAG--COM for 409.1 Driver for XP CMD20824_Setup.exe from //ftdichip.com
Device installed on com23.
NDS2 Settings:
"COM Port" 23, "Generic adaptor", "Ini Timer Offset" from -5 to +5 Not working.
Maybe bad ECM?
I reinstall elm327 usb driver and ScanTool.net V1.13. The ECM reponds normally with eml327 usb v1,5 device with ScanTool.
Any suggestions?
Conn failed
MichelCormier
Re: Conn failed
I read on the service manuel from page EL-448 that the communication is CAN H and L.
It don't work with this software.
For the USA and Canada owner, check your service manual to be sure of the compatibility off your car. Mine have a white OBD2 plug instead of a grey one describe in the NDS2.
