Dashboard settings?
Drift937
Dashboard settings?
Post by Drift937 »
Is there a way to change which gauges are shown on the dashboard? Any help is appreciated
Re: Dashboard settings?
Yes there is.
After connecting to the car go to Settings->Dash Settings. You will be able to select which gauges to show. If you want to resize or move the gauges go to Settings->Preferences and select Enable Dash Edit Mode. The background of the Dash screen will change to red and you will be able to move the gauges. Once you are happy with the layout disable the Enable Dash Edit Mode option.
