Conn Failed at "Keep Alive"
Posted: 12 May 2016, 23:57
Just purchased to check my 2007 Nissan Murano which states is a compatible ECM. Connection failed immediately after numerous attempts on all settings using the generic adapter that came with software purchase. Used "Find ECU" function and resulted in ECM active "FE". Changed search criteria to "FE" under ECm option and tried connecting again. Now runs params, regs, tests, then states "Keep Alive" and fail connections. Is this a software compatibility issue, software issue? Please help???
