I have a misfiring cylinder in my E51 Elgrand, went ahead and did the cylinder power test and turning off cylinder 6 seems to have no change so its the culprit... but which one is it? does NDS assign cylinder numbers the same as nissan as per this picture from the manual? thanks for any input.
[attachment=0]cylinder no.jpg[/attachment]
Which Cylinder?
Which Cylinder?
- cylinder no.jpg (134.21 KiB) Viewed 2411 times
Re: Which Cylinder?
Did you run the power test at idle or did you drive the car?
Is it the coil do you think?
