TPS adjustment
jerrybrown5081
TPS adjustment
Post by jerrybrown5081 »
Hi there!
Looking at getting the data scan software, one of the things I need to do is adjust my TPS on my 300zx. The nissan data scan software allows you to read the voltage being put out by the TPS to adjust it correct? And does it allow you to see if the Hard Idle Switch is on or off? Thanks!
Re: TPS adjustment
Yes, it can read the TPS voltage (Throttle) and the Closed TPS register (On/Off).
jerrybrown5081
Re: TPS adjustment
Ok awesome, so would the tps closed being on refer to the hard idle switch being on with a 300zx? Or is that backwards?
