350z HR Issues with ODB Connection
WLS350Z
Post by WLS350Z »
HI ALL
wonder if anyone can point me of assist me in the right direction.
I have a 2008 350ZHR (location South Africa)
I can use my Uprev cable to connect on my ODB port without issues, i can load / log download and upload maps.
How ever i also have a tablet in the car (Android) and an ODB 2 Bluetooth or wireless adapter, i can connect to applications such as Torque or dash command, but i cannot get any information out of it/
Locked PIDS?
is there a solution to this? has Nissan locked my ECU ?
im unsure how to Proceed
with regards to the ODB dongles, i have tried every single one in excistance.
thanks in advance
Re: 350z HR Issues with ODB Connection
Try the NDSIII Android app. It uses Nissan's Consult protocol over CAN. The same as Cipher from UpRev. You can use a generic Bluetooth ELM327 OBDII adapter with this app.
Torque and Dash Command only use the generic OBDII protocol which is not always fully supported in Nissan cars.
