Help with connection problem please!
Posted: 21 Jan 2016, 07:45
by aneudee
Is this cable (http://www.amazon.com/ScanTool-425801-O ... k+sx+cable) compatible with the nissadatascan II software? The cable has been properly installed on COM3 and i have modified the nissan data scan setting to generic cable and com3. Furthermore i have tried it with engine on, as well as off and the ecu scan does not produce any results. Thank you
Re: Help with connection problem please!
Posted: 21 Jan 2016, 12:30
This is an ELM327 based adapter cable. It will not work with the NDSII PC software. You need a VAG COM cable.
