spec v 2002
ECU dumps, maps, ROM files, log files and tunning discussions
moldbruja
spec v 2002
Post by moldbruja »
hi there i recently install my c1 cams and springs bsr, header, pulleys, ported head,etc on my spec v so im in the huge need of reflashing new changes on my ecu like i higher rev limiter 7200. im doing baby steps since i dont know exactly where to start, i think my first step should be pick a interface capable of identify this mcu right????? 02 spec v 5l ecu uses a 256 pin mcu same pin arrangement as a sh7055!!!
moldbruja
Re: spec v 2002
Post by moldbruja »
a pic of my ecu!!!
Re: spec v 2002
You should get yourself NDSII software and dump the .bin file. Unless you already have one.
moldbruja
Re: spec v 2002
Post by moldbruja »
nds sofware would download dump using any cable
n00bz
Re: spec v 2002
Post by n00bz »
Did you ever dump this?
moldbruja
Re: spec v 2002
Post by moldbruja »
yep and actually made a deffinition for it please check qr25de tunning setion in the ext minutes
