nissan primera yd22ddt 93kw 2002
marinexix
Post by marinexix »
is my first time here an always use bluetooth elm 327 to control water temp, but a ask kkl 409.1 but I dont know how configurate laptop to use, have windows 10 some body can help me, the program connect with the ecus but the button no chage to push and always rescan with connect never do another thing. My driver instal when putin the usbe kkl 409.1 an put in accesories usb serial CH340 is ok that driver o need another driver, with this recognise the ecu but always conected, with ftdi no found port. When connect tu ecu give me the ecu number plus soft 0x00
thanks :idea:
Re: nissan primera yd22ddt 93kw 2002
Use the ECMD tab to connect to your engine ecu. You also need to activate the software to access all functions.
marinexix
Post by marinexix »
I get license for this software an in my first comunication I scan all ECU`S an find addres 12,28,33,48 and F1. I know de addres 12,28 and 48 but I dont know addres 33 and F1 wich is. Some body know what is this two addres? If change value of 28 by 33 on BCM i get teste of doors lock and rear defoger but I dont know if is for that ecu or not some body can guide me?
