windows 10
jdb53
windows 10
Post by jdb53 »
trying to load onto my laptop with windows 10. get comclt... error, help
yellambo
Re: windows 10
Post by yellambo »
Hi
Had the same error during set up on my laptop running windows 10. Have you had any luck solving the problem?
phallingau
Re: windows 10
Post by phallingau »
just a stab in the dark but be sure to try the obvious things like compatibility settings (run as administrator, run compatible for winxp sp3 etc).
not sure what drives the gfx of nds but if your computer has directplay disabled in windows features i suggest enabling it, that could also fix ur problem ^_^
good luck ^_^
G20-Budo
Re: windows 10
Post by G20-Budo »
Did anyone get the Windows 10 installation issue sorted out?
I'm getting this error when I try to install nissan datascan 1 on my windows laptop "Invalid command-line parameters. Unable to continue."
Is there a fix for this? Or an update to allow NDS 1 to work on Windows 10? This is a great product and I'd really like to continue using it.
Re: windows 10
The comctl error is related to missing (or unregistered) comctl32.ocx library. It's a common error in most Windows versions.
Basically you need to locate (or download) the comctl32.ocx file and register it with regsvr32 command. See for more details: http://answers.microsoft.com/en-us/wind ... a4852e1c8e
