Small OBD Adapter
Small OBD Adapter
I would like to permanently mount NDSII in my car. Does anyone know of a small OBD adapter that is compatible with NDSII and is small enough (preferably with the cable mounted on the side instead of coming out the end) that it won't get in the way during daily use?
Re: Small OBD Adapter
Hi gregfcarlson,
There are quite a few options available for you. I briefly searched Amazon and found a wide variety of 16 pin OBD II extensions with the cable off the side instead of straight out. Here is a link to one I found that is offered in multiple lengths. Enjoy.
http://www.amazon.com/Diageng-Ultra-Pro ... sion+cable
Thank you. That looks perfect. I hadn't thought of an extension - I was trying to find an OBDII cable with a right angle that would work with NDS.
