Additional Sensor Data
gregfcarlson
Post by gregfcarlson »
I have a 2003 350Z which does not have a wideband O2 sensor. I added two wideband O2 sensors (one for each bank) from Innovate Motorsports that output a serial data stream as well as analog outputs. Is there any way to get data from those other sensors into NDSII so it can be shown on the same gauge display with the OBDII data? Either Windows or Android would be great.
Re: Additional Sensor Data
Yes, the NDSII PC software supports Innovate WBO2 controllers. You can connect to the Innovate WBO2 controller from the WBO2 tab and then add the WBO2 gauge to the Data Display window. You can also include WBO2 in the data logs.
gregfcarlson
Thank you. That's good news. So the OBD2 dongle would connect to NDSII through one USB port and the Innovate WBO2 sensors would connect in through a second USB port?
That is correct.
The WBO2 will get a Com Port assigned to it by Windows OS. You just need to select that Com Port from the WBO2 tab.
