Hi im using latest 2.53 version with ECMD key programing. I converted my BCM code to a 4 digit pin but when I start the programing an error message in the same box appears in red (Program Failed). please help, is this software related or pin related?
Thanks, loving the software
Andrew
Key programing program failed
Re: Key programing program failed
I,m in the same boat. My says failed as well. Did you buy the generator?
I also did get fail message but keys are working
P12 2.2 diesel EDM
P12 2.2 diesel EDM
I have the same problem in a Almera N16 2.2DI, it always says Program Failed. Is there a way to tell if the PIN is wrong or something else?
I have the same with pin code, I write the pin code give the dealer in the keys when buy my car but give me error in red when try to program new key p12 2.2 ECMD
