Nissan Primera P12 tickover 2,000-2,500 revs cannot adjust
David.W
Post by David.W »
Please can you help
I have a Nissan Primera SVE CVT 2005 2,000 petrol automatic only covered 100,000 miles all services done up to this 100,000 milesand full service at 80,000 miles so well maintained and Nissan consult 2 detects usng VAG connection my EU 23710-BA075 Software :( 0x00 can only connect to ECM and OB11 The engine is QR20 something cant remember other letters
Problem I have is took off throttle for cleaning as car was revving 1,400 tick over at that time when I bought it last November 2014 and car now revs up/down on tick over 2-2,500 revs tried realerning manualy no good pull out throttle fuse and car is an even 650 revs I have change the throttle and pedal for second hand put on different times no improvement bought new lamdas no change new maf no change even bought consult 3 software not realising it needed a VI connection paid Nissan £81 for diagnostic no real answer paid another Nissan main dealer £106 still no answer said cat or lambda but car has just flew MOT low emotions by pulling out throttle fuse when low revs needed also flew all other parts of MOT Nissan consult 2 said learning complete twice now and 4times failed I think as gear box oil temperature too low but car is still revving like hell can't find air or vacuum leak do not know how to fix any ideas as have paid Nissan they don't have a clue checked wiring as far as I safely can and changed a load of parts running out of money and ideas please advise NO code only at all on conslt 2 other diagnostic says Misfire pending and that is all
thank you Dave.W
David.W
Re: Nissan Primera P12 tickover 2,000-2,500 revs cannot adju
Post by David.W »
Since first asking if anyone could help me I have tried the learning etc in the end I had it to say completed but then on starting the car the revs are still 2-2,500 up/down on tickover so consult 2nd saying nothing wrong and yet still as previously said please please can anyone help this problem is no good for my automatic gear box and yet when driving revs go up change gear down ect in other words car drives tidy but will bot fall below 1,200 when driving and mpg are not too bad as well as plenty of power so what is causing my fault
Thank you
It sounds like you have changed lot of parts and spend a lot of money trying to fix it.
Since there are no error codes it's probably not caused by a faulty sensor. You should try doing the IAVL. It needs to be completed with the engine running. It will probably fail because your idle RPM is too high so you need to do something to lower the RPM. Try disconnecting one of the spark plugs or even 2. I have heard of some people using this technique to complete the IAVL.
David.W
Post by David.W »
Hello Tom
Thank for your advice I have tried the air learning several times now with different 3 throttles and map sensors ect even changed PCV valve test has passed each time but not attempted it with engine running but what I did find was on running the engine going into ActiveTests putting A/F base down to 75% and clicked start then my revs would steady up at 1,200 and also still rev up tidy and back to 1,200 until I have to close program as there is no way of saving that setting is this telling you anything of my fault?
Thank you
Dave
David.W
Post by David.W »
Hello
Just to let you know I fixed the car about a month ago and have done around 1,500 miles since then car has an even tickover of 650 revs in park thanks to this program took 2 minutes to fix and I have bought all these parts for nothing as all original parts back on my car I have nothing good to say about Nissan themselves as they didn't want to know I was going to sell my car cheap because no one had a clue of the fault even that Nissan dealership said after diagnostic not a clue they would have to have my car at least 3hour then could not guaranty to fix it as I took car from them instead of leaving it for god knows how much of a bill there was no chance of getting my diagnostic money back the software they use is supposedly far superior to this one so why were they not able to find the fault ( which did not exist) and fix the car as said it took me minutes to get it running right I am sure it is only for extra money although the mechanic honestly did not have a clue good old Nissan dealers go back to school and learn about your cars
Dave
:D
Good to hear Dave. What did you have to do to fix it?
David.W
Post by David.W »
Hello Tom
Fixed it by warming engine up start engine 2,000-2,500 revs take off plug lead revs went down take second plug lead of revs still too high took off 3rd plug lead engine now running on one plug at 800-900 revs no trouble then pressed to relearn air volume on laptop and engine stopped reconnected all plugs and a steady 700 revs which I have now done over 3,000 miles at average 33-37mpg thanks to your program took me 4 months to sort out and Nissan themselves have not a clue all my original parts are back so I wasted a lot of money even on Nissan diagnostic and was going to sell this car cheap and yet it flew its mot with no advisories anybody want cheap throttle or accelerator pedal l let me know to try and get diagnostic money back told Nissan I can reproduce fault which they cannot mend and then press button on laptop and i fixed they did not want to know
Dave
:D
David.W
Post by David.W »
Hello Tom
Further to my fix I would like to say that I would never ever believe a car would turn over on one plug and just compression still on the other 3 cylinders least of all do 8-900 revs if this trouble accrued on a diesel all you would have to do is unplug the injectors with engine running ANYONE LIVING NEAR ME WANTING ADVICE OR ME TO CHECK IT OUT PLEASE CONTACT ME THIS APPLIES TO ALL NISSAN NOT JUST PRIMERA I am now thinking of putting my old STAG LPG set up on but not sure if there is enough space to screw the LPG injector tubes in the inlet manifold also where and if there is enough room to fit the regulator and gas valve and valve saver unit under the bonnet any advice with photos welcome
Dave
