Clear Self Learn and Idle Air Volume Learn
G35CO
Post by G35CO »
Hello, I’m getting ready to clean the TB in my 03 G35 sedan and would like to use the Clear Self Learn and Idle Air Volume Learn in the Work Support.
Do i need to have the car running in order to perform these works?
Should i clear the self-learn first and then do the idle learn?
Is there a specific steps i need to follow or conditions i need to insure before i run these steps?
After i clean the TB i need to preform several steps and i was wondering if we can add them to the support group. I need to complete the following steps:
1. PERFORM ACCELERATOR PEDAL RELEASED POSITION LEARNING
2. PERFORM THROTTLE VALVE CLOSED POSITION LEARNING
Great app!!!
Re: Clear Self Learn and Idle Air Volume Learn
The engine should be running.
Yes, clear self-learn first.
Yes, there are a few conditions you need to meet to successfully complete IAVL. Check the service manual.
The position learning functions are automatically performed by the ECU and can not be initiated by a software.
