Is NDS II Compatible with USDM 2003 Infinity G35 Coupe?
CLRH2O
Post by CLRH2O »
As the title says - is NDS II fully compatible with the 2003 year USDM Infiniti G35 Coupe?
I'm considering this as an alternative to a CONSULT II hardware setup.
Re: Is NDS II Compatible with USDM 2003 Infinity G35 Coupe?
Yes, the NDSII software is compatible with G35 coupe ECM, TCM, ABS and SRS ECUs. The BCM ECU might not be supported depending on the BCM model. You can confirm this by testing connection to BCM with unregistered software.
